Support pour la version 2.0.0
Problème "INFINITE LOOP" - Joomla 1.5.26
24 Jul 2012 17:11 #1 par fanfouet
J'ai installé Kunena en local sans aucun problème .... :)
mais j'ai un problème lors de l’installation sur le site en ligne....
Est ce déjà arriver à d'autres utilisateurs????
mes droits d'instal sont pourtant en 777
Je vous remercie d'avance pour vos conseils,
Fanfouet
INFINITE LOOP
SEHP probleme instalation
Warning: file_exists() [function.file-exists]: open_basedir restriction in effect. File(/home/www/tmp) is not within the allowed path(s): (/home/www/e891e6fa02e43c1f0af7162fe52f21f0:/tmp:/opt/php/lib/php) in /home/www/e891e6fa02e43c1f0af7162fe52f21f0/web/libraries/joomla/filesystem/file.php on line 329
Warning: is_dir() [function.is-dir]: open_basedir restriction in effect. File(/home/www) is not within the allowed path(s): (/home/www/e891e6fa02e43c1f0af7162fe52f21f0:/tmp:/opt/php/lib/php) in /home/www/e891e6fa02e43c1f0af7162fe52f21f0/web/libraries/joomla/filesystem/folder.php on line 392
Warning: is_dir() [function.is-dir]: open_basedir restriction in effect. File(/home) is not within the allowed path(s): (/home/www/e891e6fa02e43c1f0af7162fe52f21f0:/tmp:/opt/php/lib/php) in /home/www/e891e6fa02e43c1f0af7162fe52f21f0/web/libraries/joomla/filesystem/folder.php on line 392
Warning: is_dir() [function.is-dir]: open_basedir restriction in effect. File(/) is not within the allowed path(s): (/home/www/e891e6fa02e43c1f0af7162fe52f21f0:/tmp:/opt/php/lib/php) in /home/www/e891e6fa02e43c1f0af7162fe52f21f0/web/libraries/joomla/filesystem/folder.php on line 392
Warning: is_writeable() [function.is-writeable]: open_basedir restriction in effect. File(/home/www/tmp) is not within the allowed path(s): (/home/www/e891e6fa02e43c1f0af7162fe52f21f0:/tmp:/opt/php/lib/php) in /home/www/e891e6fa02e43c1f0af7162fe52f21f0/web/libraries/joomla/filesystem/file.php on line 351
Warning: is_file() [function.is-file]: open_basedir restriction in effect. File(/home/www/tmp/com_kunena_v2.0.1_2012-07-07.zip) is not within the allowed path(s): (/home/www/e891e6fa02e43c1f0af7162fe52f21f0:/tmp:/opt/php/lib/php) in /home/www/e891e6fa02e43c1f0af7162fe52f21f0/web/libraries/joomla/filesystem/archive/zip.php on line 126
