Modification pied de page
11 Oct 2010 11:52 #7 par Azote
Réponse de Azote sur le sujet Re:Modification pied de page
Ok!
Merci pour la réponse rapide.
Je fait ma modif ce soir.
Cdlt
11 Oct 2010 15:44 #8 par Azote
Voila ce que j'ai fait pour ma part.
// Credits echo '<b>Moderateur: </b><a href = "http://oldstar.verygames.net/index.php?option=com_comprofiler&Itemid=9">Azote</a>'; echo '<div class="fb_credits"> ' .CKunenaLink::GetCreditsLink();
Cdlt
08 Fév 2011 17:52 #9 par shadow76
Réponse de shadow76 sur le sujet Re:Modification pied de page
sa apparaît ou:
<?php
* @version $Id: kunena.php 3321 2010-08-28 14:59:50Z mahagr $
* Kunena Component
* @package Kunena
* @Copyright (C) 2008 - 2010 Kunena Team All rights reserved
* @license www.gnu.org/copyleft/gpl.html GNU/GPL
* @link www.kunena.com
* Based on FireBoard Component
* @Copyright (C) 2006 - 2007 Best Of Joomla All rights reserved
* @link www.bestofjoomla.com
* Based on Joomlaboard Component
* @copyright (C) 2000 - 2004 TSMF / Jan de Graaff / All Rights Reserved
* @author TSMF & Jan de Graaff
// Dont allow direct linking
defined( '_JEXEC' ) or die();
// Kunena wide defines
require_once (JPATH_COMPONENT . DS . 'lib' . DS . 'kunena.defines.php');
class KunenaApp {
function __construct() {
ob_start();
kimport('error');
// Display time it took to create the entire page in the footer
jimport( 'joomla.error.profiler' );
$__kstarttime = JProfiler::getmicrotime();
$lang = JFactory::getLanguage();
if (!$lang->load('com_kunena', JPATH_SITE, null, true)) {
$lang->load('com_kunena', KPATH_SITE);
// First of all take a profiling information snapshot for JFirePHP
if(JDEBUG){
require_once (JPATH_COMPONENT . DS . 'lib' . DS . 'kunena.profiler.php');
$__profiler = KProfiler::GetInstance();
$__profiler->mark('Start');
$func = JString::strtolower ( JRequest::getCmd ( 'func', JRequest::getCmd ( 'view', '' )) );
JRequest::setVar ( 'func', $func );
require_once(KUNENA_PATH . DS . 'router.php');
if ($func && !in_array($func, KunenaRouter::$functions)) {
// If func is not legal, raise joomla error
return JError::raiseError( 500, 'Kunena function "' . $func . '" not found' );
if (empty($_POST)) {
// Set active menuitem so that Kunena menu shows up
$menu = JSite::getMenu ();
$active = $menu->getActive ();
// Legacy menu item support (get best match from Kunena Menu)
if (empty($active->query )) {
$menu->setActive ( KunenaRoute::getItemID () );
// If we are currently in entry page, we need to show and highlight default menu item
if (! $func || $func == 'entrypage') {
$defaultitem = 0;
if (!empty ( $active->query )) {
$defaultitem = $active->query ;
$menu->setActive ( KunenaRoute::getItemID ( $defaultitem ) );
if (is_object ( $active )) {
foreach ( $active->query as $var => $value ) {
if ($var == 'view')
$var = 'func';
if ($var == 'func' && $value == 'entrypage')
$value = $func;
JRequest::setVar ( $var, $value );
$func = JRequest::getCmd ( 'func' );
global $message;
global $kunena_this_cat;
// Get all the variables we need and strip them in case
$action = JRequest::getCmd ( 'action', '' );
$catid = JRequest::getInt ( 'catid', 0 );
$contentURL = JRequest::getVar ( 'contentURL', '' );
$do = JRequest::getCmd ( 'do', '' );
$task = JRequest::getCmd ( 'task', '' );
$email = JRequest::getVar ( 'email', '' );
$favoriteMe = JRequest::getVar ( 'favoriteMe', '' );
$fb_authorname = JRequest::getVar ( 'fb_authorname', '' );
$fb_thread = JRequest::getInt ( 'fb_thread', 0 );
$id = JRequest::getInt ( 'id', 0 );
$limit = JRequest::getInt ( 'limit', 0 );
$limitstart = JRequest::getInt ( 'limitstart', 0 );
$markaction = JRequest::getVar ( 'markaction', '' );
$message = JRequest::getVar ( 'message', '' );
$page = JRequest::getInt ( 'page', 0 );
$parentid = JRequest::getInt ( 'parentid', 0 );
$pid = JRequest::getInt ( 'pid', 0 );
$replyto = JRequest::getInt ( 'replyto', 0 );
$resubject = JRequest::getVar ( 'resubject', '' );
$rowid = JRequest::getInt ( 'rowid', 0 );
$rowItemid = JRequest::getInt ( 'rowItemid', 0 );
$subject = JRequest::getVar ( 'subject', '' );
$subscribeMe = JRequest::getVar ( 'subscribeMe', '' );
$thread = JRequest::getInt ( 'thread', 0 );
$topic_emoticon = JRequest::getVar ( 'topic_emoticon', '' );
$userid = JRequest::getInt ( 'userid', 0 );
$no_html = JRequest::getBool ( 'no_html', 0 );
$kunena_app = JFactory::getApplication ();
// If JFirePHP is installed and enabled, leave a trace of the Kunena startup
if(JDEBUG == 1 && defined('JFIREPHP')){
// FB::trace("Kunena Startup");
// Redirect Forum Jump
if (isset ( $_POST ) && $func == "showcat") {
header ( "HTTP/1.1 303 See Other" );
header ( "Location: " . KunenaRoute::_ ( 'index.php?option=com_kunena&func=showcat&catid=' . $catid, false ) );
$kunena_app->close ();
$kunena_my = &JFactory::getUser ();
$kunena_db = &JFactory::getDBO ();
$kunena_config = KunenaFactory::getConfig ();
if ($kunena_config->debug) {
@ini_set('display_errors', 1);
@error_reporting(E_ALL);
$kunena_db->debug(1);
global $lang, $topic_emoticons;
// Class structure should be used after this and all the common task should be moved to this class
require_once (JPATH_COMPONENT . DS . 'class.kunena.php');
// Central Location for all internal links
require_once (JPATH_COMPONENT . DS . 'lib' . DS . 'kunena.link.class.php');
require_once (JPATH_COMPONENT . DS . 'lib' . DS . 'kunena.smile.class.php');
// Redirect profile (menu item) to the right component
if ($func == 'profile' && !$do && empty($_POST)) {
$profileIntegration = KunenaFactory::getProfile();
if (!($profileIntegration instanceof KunenaProfileKunena)) {
$url = CKunenaLink::GetProfileURL($kunena_my->id, false);
if ($url) $kunena_app->redirect($url);
// Check for JSON request
if ($func == "json") {
FB::log('Kunena JSON request');
// URL format for JSON requests: e.g: index.php?option=com_kunena&func=json&action=autocomplete&do=getcat
require_once (JPATH_COMPONENT . DS . 'lib' . DS . 'kunena.ajax.helper.php');
$ajaxHelper = &CKunenaAjaxHelper::getInstance();
// Get the document object.
$document =& JFactory::getDocument();
// Set the MIME type for JSON output.
$document->setMimeEncoding( 'application/json' );
// Change the suggested filename.
if ($action!='uploadfile') JResponse::setHeader( 'Content-Disposition', 'attachment; filename="kunena.json"' );
$value = JRequest::getVar ( 'value', '' );
JResponse::sendHeaders();
if ($kunena_config->board_offline && ! CKunenaTools::isAdmin ()){
// when the forum is offline, we don't entertain json requests
json_encode ( array(
'status' => '0',
'error' => @sprintf(_KUNENA_FORUM_OFFLINE)) );
else {
// Generate reponse
echo $ajaxHelper->generateJsonResponse($action, $do, $value);
if ($kunena_config->board_offline && ! CKunenaTools::isAdmin ()) {
// if the board is offline
echo $kunena_config->offline_message;
} else if ($kunena_config->regonly && ! $kunena_my->id) {
// if we only allow registered users
if (file_exists ( KUNENA_JTEMPLATEPATH .DS. 'css' .DS. 'kunena.forum-min.css' )) {
CKunenaTools::addStyleSheet ( KUNENA_JTEMPLATEURL . '/css/kunena.forum-min.css' );
} else {
CKunenaTools::addStyleSheet ( KUNENA_TMPLTCSSURL );
echo '<div id="Kunena">';
CKunenaTools::loadTemplate('/login.php');
echo '</div>';
} else {
// Forum is online:
//intercept the RSS request; we should stop afterwards
if ($func == 'rss') {
require_once ( JPATH_COMPONENT.DS.'funcs'.DS.'rss.php');
$feed = new CKunenaRSSView($catid);
$feed->display();
if ($func == 'fb_pdf' || $func == 'pdf') {
include (JPATH_COMPONENT.DS.'lib'.DS.'kunena.pdf.php');
$format = JRequest::getCmd ( 'format', 'html' );
if ($format != 'html') {
echo "Kunena: Unsupported output format {$format}, please use only format=html or .html";
$integration = KunenaFactory::getProfile();
$integration->open();
//time format
include_once (JPATH_COMPONENT . DS . 'lib' . DS . 'kunena.timeformat.class.php');
$document = & JFactory::getDocument ();
if (file_exists ( KUNENA_ABSTMPLTPATH . '/initialize.php' )) {
require_once ( KUNENA_ABSTMPLTPATH . '/initialize.php' );
} else {
require_once (KPATH_SITE . '/template/default/initialize.php');
// Insert WhoIsOnlineDatas
require_once (KUNENA_PATH_LIB .DS. 'kunena.who.class.php');
$who =& CKunenaWhoIsOnline::getInstance();
$who->insertOnlineDatas ();
// include required libraries
jimport('joomla.template.template');
// Kunena Current Template Icons Pack
if (file_exists ( KUNENA_ABSTMPLTPATH . '/icons.php' )) {
include (KUNENA_ABSTMPLTPATH . '/icons.php');
} else {
include (KUNENA_PATH_TEMPLATE_DEFAULT . DS . 'icons.php');
if(JDEBUG){
$__profiler->mark('Session Start');
// We only save session for registered users
$kunena_session = KunenaFactory::getSession ( true );
if ($kunena_my->id > 0) {
// new indicator handling
if ($markaction == "allread") {
if (!JRequest::checkToken()) {
$kunena_app->enqueueMessage ( JText::_ ( 'COM_KUNENA_ERROR_TOKEN' ), 'error' );
$kunena_app->redirect ( CKunenaLink::GetCategoryURL('listcat', $catid, false) );
$kunena_session->markAllCategoriesRead ();
if (!$kunena_session->save ()) $kunena_app->enqueueMessage ( JText::_('COM_KUNENA_ERROR_SESSION_SAVE_FAILED'), 'error' );
$kunena_app->redirect ( CKunenaLink::GetCategoryURL('listcat', $catid, false), JText::_('COM_KUNENA_GEN_ALL_MARKED') );
$userprofile = KunenaFactory::getUser($kunena_my->id);
if ($userprofile->posts === null) {
$userprofile->save();
//$userprofile = KunenaFactory::getUser($kunena_my->id, true);
// Assign previous visit without user offset to variable for templates to decide
$this->prevCheck = $kunena_session->lasttime;
} else {
// For guests we don't show new posts
$this->prevCheck = CKunenaTimeformat::internalTime()+60;
if(JDEBUG){
$__profiler->mark('Session End');
//Get the topics this user has already read this session from #__kunena_sessions
$this->read_topics = explode ( ',', $kunena_session->readtopics );
/* _\|/_
(o o)
+----oOO-{_}-OOo
| Until this section we have included the |
| necessary files and gathered the required |
| variables. Now let's start processing |
| them |
if ($kunena_config->highlightcode) {
$document->addStyleDeclaration('
div.highlight pre {
width: '.(($kunena_config->rtewidth * 9) / 10).'px;
max-height: '.$kunena_config->rteheight.'px
//Check if the catid requested is a parent category, because if it is
//the only thing we can do with it is 'listcat' and nothing else
if ($func == "showcat") {
if ($catid != 0) {
$kunena_db->setQuery ( "SELECT parent FROM #__kunena_categories WHERE id='{$catid}'" );
$catParent = intval($kunena_db->loadResult ());
if (KunenaError::checkDatabaseError()) return;
if ($catid == 0 || $catParent == 0) {
$kunena_app->redirect ( CKunenaLink::GetCategoryURL('listcat',$catid, false) );
<div id="Kunena"><?php
if ($kunena_config->board_offline) {
<span id="fbOffline"><?php
echo JText::_('COM_KUNENA_FORUM_IS_OFFLINE')?></span> <?php
<?php
if(JDEBUG){
$__profiler->mark('Profilebox Start');
CKunenaTools::loadTemplate('/menu.php');
CKunenaTools::displayLoginBox();
if(JDEBUG){
$__profiler->mark('Profilebox End');
// Handle help / rules menuitems
if ($func == 'article') {
$func = $do;
if(JDEBUG){
$__profiler->mark('$func Start');
switch ($func) {
case 'who' :
$online =& CKunenaWhoIsOnline::getInstance();
$online->displayWho();
break;
case 'announcement' :
require_once (KUNENA_PATH_LIB .DS. 'kunena.announcement.class.php');
$ann = CKunenaAnnouncement::getInstance();
$ann->display();
break;
case 'poll':
require_once (KUNENA_PATH_LIB .DS. 'kunena.poll.class.php');
$kunena_polls =& CKunenaPolls::getInstance();
$kunena_polls->display();
break;
case 'polls':
$kunena_polls->polldo();
break;
case 'stats' :
require_once(KUNENA_PATH_LIB .DS. 'kunena.stats.class.php');
$kunena_stats = new CKunenaStats ( );
$kunena_stats->showStats ();
break;
case 'myprofile' :
case 'userprofile' :
case 'fbprofile' :
case 'profile' :
case 'moderateuser' :
require_once ( KUNENA_PATH_FUNCS .DS. 'profile.php');
$page = new CKunenaProfile($userid, $task ? $task : $do);
$page->display();
break;
case 'userlist' :
require_once (KUNENA_PATH_FUNCS . DS . 'userlist.php');
$page = new CKunenaUserlist();
$page->display();
break;
case 'post' :
require_once (KUNENA_PATH_FUNCS . DS . 'post.php');
$page = new CKunenaPost();
$page->display();
break;
case 'view' :
require_once (KUNENA_PATH_FUNCS . DS . 'view.php');
$page = new CKunenaView($func, $catid, $id, $limitstart, $limit);
$page->display(true);
break;
case 'showcat' :
require_once (KUNENA_PATH_FUNCS . DS . 'showcat.php');
$page = new CKunenaShowcat($catid, $page);
$page->display();
break;
case 'listcat' :
require_once (KUNENA_PATH_FUNCS . DS . 'listcat.php');
$page = new CKunenaListcat($catid);
$page->display();
break;
case 'review' :
require_once (KUNENA_PATH_LIB . DS . 'kunena.review.php');
$review = new CKunenaReview($catid);
$review->display();
break;
case 'rules' :
case 'help' :
CKunenaTools::loadTemplate('/'.$func.'.php');
break;
case 'report' :
require_once(KUNENA_PATH_LIB .DS. 'kunena.report.class.php');
$report = new CKunenaReport();
$report->display();
break;
case 'latest' :
case 'mylatest' :
case 'noreplies' :
case 'subscriptions' :
case 'favorites' :
case 'userposts' :
case 'unapproved' :
case 'deleted' :
require_once (KUNENA_PATH_FUNCS . DS . 'latestx.php');
if ($do) $func = $do;
$page = new CKunenaLatestX($func, $page);
$page->display();
break;
case 'search' :
case 'advsearch' :
require_once (JPATH_COMPONENT . DS . 'lib' . DS . 'kunena.search.class.php');
$kunenaSearch = new CKunenaSearch ( );
$kunenaSearch->show ();
break;
case 'markthisread' :
if (!JRequest::checkToken('get')) {
$kunena_app->redirect ( CKunenaLink::GetCategoryURL('showcat' , $catid, false ), JText::_('COM_KUNENA_GEN_FORUM_MARKED') );
// Mark all unread topics in the category to read
$readTopics = $kunena_session->readtopics;
$kunena_db->setQuery ( "SELECT thread FROM #__kunena_messages WHERE catid='{$catid}' AND parent=0 AND thread NOT IN ({$readTopics})" );
$readForum = $kunena_db->loadResultArray ();
$readTopics = implode(',', array_merge(explode(',', $readTopics), $readForum));
$kunena_db->setQuery ( "UPDATE #__kunena_sessions set readtopics='$readTopics' WHERE userid=$kunena_my->id" );
$kunena_db->query ();
break;
case 'subscribecat' :
if ($userid == 0) {
$kunena_app->redirect ( CKunenaLink::GetCategoryURL('showcat' , $catid, false ) );
} else {
$kunena_app->redirect ( CKunenaLink::GetProfileURL($userid, false) );
$success_msg = '';
if ( $catid && $kunena_my->id ) {
$query = "INSERT INTO #__kunena_subscriptions_categories (catid, userid) VALUES ('$catid','$kunena_my->id')";
$kunena_db->setQuery ( $query );
if (@$kunena_db->query () && $kunena_db->getAffectedRows () == 1) {
$success_msg = JText::_('COM_KUNENA_GEN_CATEGORY_SUBCRIBED');
KunenaError::checkDatabaseError();
$kunena_app->redirect ( CKunenaLink::GetCategoryURL('showcat' , $catid, false ), $success_msg );
break;
case 'unsubscribecat' :
if ($userid == 0) {
} else {
$kunena_app->redirect ( CKunenaLink::GetProfileURL($userid, false), $success_msg );
$success_msg = '';
if ($catid && $kunena_my->id ) {
$query = "DELETE FROM #__kunena_subscriptions_categories WHERE catid=$catid AND userid=$kunena_my->id";
if ($kunena_db->query () && $kunena_db->getAffectedRows () == 1) {
$success_msg = JText::_('COM_KUNENA_GEN_CATEGORY_UNSUBCRIBED');
if ($userid == 0) {
} else {
break;
case 'karma' :
include (JPATH_COMPONENT . DS . 'lib' . DS . 'kunena.karma.php');
break;
case 'thankyou':
require_once(JPATH_COMPONENT.DS.'lib'.DS.'kunena.thankyou.php');
$thankyou = new CKunenaThankyou ();
$thankyou->setThankyou();
break;
case 'bulkactions' :
switch ($do) {
case "bulkDel" :
CKunenaTools::KDeletePosts ( );
break;
case "bulkMove" :
CKunenaTools::KMovePosts ( $catid );
break;
case "bulkFavorite" :
$kunena_app->redirect ( CKunenaLink::GetProfileURL($kunena_my->id, false) );
require_once(JPATH_ROOT.DS.'administrator/components/com_kunena/libraries/api.php');
$KunenaUserAPI = new KunenaUserAPI();
$cb = KGetArrayReverseInts ( "cb" );
$result = $KunenaUserAPI->unfavoriteThreads($kunena_my->id, $cb);
if ( $result ) {
$message = JText::_('COM_KUNENA_USER_UNFAVORITE_YES');
} else {
$message = JText::_('COM_KUNENA_POST_UNFAVORITED_TOPIC');
$kunena_app->redirect(CKunenaLink::GetProfileURL($kunena_my->id, false),$message);
break;
case "bulkSub" :
$result = $KunenaUserAPI->unsubscribeThreads($kunena_my->id, $cb);
if ( $result ) {
$message = JText::_('COM_KUNENA_USER_UNSUBSCRIBE_YES');
} else {
$message = JText::_('COM_KUNENA_POST_NO_UNSUBSCRIBED_TOPIC');
break;
case "bulkDelPerm" :
CKunenaTools::KDeletePerm ( );
break;
case "bulkRestore" :
CKunenaTools::KUndelete ( );
break;
break;
case 'templatechooser' :
$fb_user_template = strval ( JRequest::getVar ( 'kunena_user_template', '', 'COOKIE' ) );
$fb_user_img_template = strval ( JRequest::getVar ( 'kunena_user_img_template', $fb_user_img_template ) );
$fb_change_template = strval ( JRequest::getVar ( 'kunena_change_template', $fb_user_template ) );
$fb_change_img_template = strval ( JRequest::getVar ( 'kunena_change_img_template', $fb_user_img_template ) );
if ($fb_change_template) {
// clean template name
$fb_change_template = preg_replace ( '#\W#', '', $fb_change_template );
if (JString::strlen ( $fb_change_template ) >= 40) {
$fb_change_template = JString::substr ( $fb_change_template, 0, 39 );
// check that template exists in case it was deleted
if (file_exists ( KUNENA_PATH_TEMPLATE . DS . $fb_change_template . '/css/kunena.forum.css' )) {
$lifetime = 60 * 10;
$fb_current_template = $fb_change_template;
setcookie ( 'kunena_user_template', "$fb_change_template", time () + $lifetime );
} else {
setcookie ( 'kunena_user_template', '', time () - 3600 );
if ($fb_change_img_template) {
$fb_change_img_template = preg_replace ( '#\W#', '', $fb_change_img_template );
if (JString::strlen ( $fb_change_img_template ) >= 40) {
$fb_change_img_template = JString::substr ( $fb_change_img_template, 0, 39 );
if (file_exists ( KUNENA_PATH_TEMPLATE . DS . $fb_change_img_template . '/css/kunena.forum.css' )) {
$fb_current_img_template = $fb_change_img_template;
setcookie ( 'kunena_user_img_template', "$fb_change_img_template", time () + $lifetime );
} else {
setcookie ( 'kunena_user_img_template', '', time () - 3600 );
$kunena_app->redirect ( CKunenaLink::GetKunenaURL(false) );
break;
case 'credits' :
include (JPATH_COMPONENT . DS . 'lib' . DS . 'kunena.credits.php');
break;
default :
$page->display();
break;
if(JDEBUG){
$__profiler->mark('$func End');
// Bottom Module
CKunenaTools::showModulePosition( 'kunena_bottom' );
// RSS
if ($kunena_config->enablerss) {
echo '<div class="krss-block">';
$rss_params = ((int) $catid > 0 ? '&amp;catid=' . (int) $catid : '');
$document->addCustomTag ( '<link rel="alternate" type="application/rss+xml" title="' . JText::_('COM_KUNENA_LISTCAT_RSS') . '" href="' . CKunenaLink::GetRSSURL($rss_params) . '" />' );
echo CKunenaLink::GetRSSLink ( CKunenaTools::showIcon ( 'krss', JText::_('COM_KUNENA_LISTCAT_RSS') ), 'follow', $rss_params );
echo '</div>';
$template = KunenaFactory::getTemplate();
$this->params = $template->params;
// Credits
echo '<div class="kcredits kms"> ' . CKunenaLink::GetTeamCreditsLink ( $catid, JText::_('COM_KUNENA_POWEREDBY') ) . ' ' . CKunenaLink::GetCreditsLink ();
if ($this->params->get('templatebyText') !=''):
echo ' :: <a href ="'. $this->params->get('templatebyLink').'" rel="follow">' . $this->params->get('templatebyText') .' '. $this->params->get('templatebyName') .'</a>';
endif;
echo '</div>';
// display footer
// Show total time it took to create the page
$__ktime = JProfiler::getmicrotime() - $__kstarttime;
<div class="kfooter">
<span class="kfooter-time"><?php echo JText::_('COM_KUNENA_FOOTER_TIME_TO_CREATE').'&nbsp;'.sprintf('%0.2f', $__ktime).'&nbsp;'.JText::_('COM_KUNENA_FOOTER_TIME_SECONDS');?></span>
</div>
</div>
<!-- closes Kunena div -->
<?php
$integration->close();
} // end of online
if(JDEBUG == 1){
$__profiler->mark('Done');
$__queries = $__profiler->getQueryCount();
if(defined('JFIREPHP')){
FB::log($__profiler->getBuffer(), 'Kunena Profiler');
if($__queries>50){
FB::error($__queries, 'Kunena Queries');
} else if($__queries>35){
FB::warn($__queries, 'Kunena Queries');
} else {
FB::log($__queries, 'Kunena Queries');
ob_end_flush();
* Escapes a value for output in a view script.
* If escaping mechanism is one of htmlspecialchars or htmlentities, uses
* {@link $_encoding} setting.
* @param mixed $var The output to escape.
* @return mixed The escaped value.
function escape($var)
return htmlspecialchars($var, ENT_COMPAT, 'UTF-8');
$kunena = new KunenaApp();
26 Avr 2011 07:25 #10 par websurfer
Réponse de websurfer sur le sujet Re: Modification pied de page
dans le fichier css kunena.forum-min ligne 2993 passer le texte à 0 pixel, il est là mais il est plus là
#Kunena .kcredits {
font-size: 0px
Temps de génération de la page : 0.357 secondes
