Probleme d'installation erreur SQL
- Koony
28 Mai 2009 13:06 #1
par Koony
Probleme d'installation erreur SQL a été créé par Koony
J'ai déjà installé kunena sur d'autre site en local sans problème, mais là je sèche complètement : une immense page blanche avec des messages d'erreur.
"Warning: Could not load latest Version record.\nDB function failed with error number 1146
Table 'aedeaqui.jos_fb_version' doesn't exist SQL=SELECT `version`, `versiondate`, `installdate`, `build`, `versionname` FROM `jos_fb_version` ORDER BY `id` DESC LIMIT 1;
SQL =
SELECT
`version`,
`versiondate`,
`installdate`,
`build`,
`versionname`
in /homez.184/aedeaqui/www/components/com_kunena/lib/kunena.debug.php on line 74
variable value
$0 "
key value
$file "/homez.184/aedeaqui/www/components/com_kunena/lib/kunena.debug.php"
$line "45"
$function "debug_callstackinfo"
[args] Nested Array
$1 "
key value
$file "/homez.184/aedeaqui/www/administrator/components/com_kunena/lib/fx.upgrade.class.php"
$line "109"
$function "trigger_dberror"
[args] Nested Array
$2 "
key value
$line "169"
$function "backupversiontable"
$class "fx_upgrade"
$type "->"
[args] Nested Array
$3 "
key value
$file "/homez.184/aedeaqui/www/administrator/components/com_kunena/install/kunena.install.php"
$line "98"
$function "doupgrade"
$class "fx_upgrade"
$type "->"
[args] Nested Array
$4 "
key value
$file "/homez.184/aedeaqui/www/libraries/joomla/installer/adapters/component.php"
$line "272"
$function "com_install"
[args] Nested Array
$5 "
key value
$file "/homez.184/aedeaqui/www/libraries/joomla/installer/installer.php"
$line "332"
$function "install"
$class "jinstallercomponent"
$type "->"
[args] Nested Array
$6 "
key value
$file "/homez.184/aedeaqui/www/administrator/components/com_installer/models/install.php"
$line "86"
$function "install"
$class "jinstaller"
$type "->"
[args] Nested Array
$7 "
key value
$file "/homez.184/aedeaqui/www/administrator/components/com_installer/controller.php"
$line "71"
$function "install"
$class "installermodelinstall"
$type "->"
[args] Nested Array
$8 "
key value
$file "/homez.184/aedeaqui/www/libraries/joomla/application/component/controller.php"
$line "236"
$function "doinstall"
$class "installercontroller"
$type "->"
[args] Nested Array
$9 "
key value
$file "/homez.184/aedeaqui/www/administrator/components/com_installer/admin.installer.php"
$line "44"
$function "execute"
$type "->"
[args] Nested Array
$10 "
key value
$file "/homez.184/aedeaqui/www/libraries/joomla/application/component/helper.php"
$line "162"
[args] Nested Array
$function "require_once"
$11 "
key value
$file "/homez.184/aedeaqui/www/administrator/includes/application.php"
$line "136"
$function "rendercomponent"
$class "jcomponenthelper"
$type "::"
[args] Nested Array
$12 "
key value
$file "/homez.184/aedeaqui/www/administrator/index.php"
$line "67"
$function "dispatch"
$class "jadministrator"
$type "->"
[args] Nested Array
Installed version: Kunena 1.0.x | NOT INSTALLED | [ Unknown ] | php 4.4.9 | mysql 5.0.68-log
Fatal error: Unable to backup version table.\nDB function reports no errors in /homez.184/aedeaqui/www/components/com_kunena/lib/kunena.debug.php on line 59
J'ai un joomla 1.5, mode legacy activé, hébergé chez OVH
Bref, si quelqu'un peu m'aider...mes compétences étant assez limitées!!
Merci à vous
SQL =
SELECT
`version`,
`versiondate`,
`installdate`,
`build`,
`versionname`
variable value
$0 "
key value
$line "45"
[args] Nested Array
$1 "
key value
$line "109"
[args] Nested Array
$2 "
key value
$line "169"
$class "fx_upgrade"
$type "->"
[args] Nested Array
$3 "
key value
$line "98"
$class "fx_upgrade"
$type "->"
[args] Nested Array
$4 "
key value
$line "272"
[args] Nested Array
$5 "
key value
$line "332"
$function "install"
$type "->"
[args] Nested Array
$6 "
key value
$line "86"
$function "install"
$class "jinstaller"
$type "->"
[args] Nested Array
$7 "
key value
$line "71"
$function "install"
$type "->"
[args] Nested Array
$8 "
key value
$line "236"
$type "->"
[args] Nested Array
$9 "
key value
$line "44"
$function "execute"
$type "->"
[args] Nested Array
$10 "
key value
$line "162"
[args] Nested Array
$11 "
key value
$line "136"
$type "::"
[args] Nested Array
$12 "
key value
$line "67"
$type "->"
[args] Nested Array
Merci à vous
28 Mai 2009 16:10 #2
Réponse de lavsteph sur le sujet Re:Probleme d'installation erreur SQL
je te conseille de passer ton site en php 5.0, cette erreur devrait alors disparaître.
- Koony
18 Oct 2009 16:11 #3
par Koony
Réponse de Koony sur le sujet Re:Probleme d'installation erreur SQL
mille excuses pour ne pas t'avoir répondu plus tôt.... honte sur moi donc merci infiniment de ta réponse.
Impossible de changer pour PHP5, j'ai donc opté pour FireBoard... et ça marche. Mais je ne suis pas sûre que le projet aboutisse réellement un jour...bref
merci encore et pardon pour tant d'impolitesse de ma part.
18 Oct 2009 20:17 - 18 Oct 2009 20:18 #4
Réponse de failrOn sur le sujet Re:Probleme d'installation erreur SQL
Ton problème vient du fait que l'installeur de Kunena n'a pas pu créer la table jos_fb_version dans ta base de donnée.
C'est tout à fait possible de passer à php5 avec ton hébergeur regarde là : guides.ovh.net/Php5ChezOvh
C'est dommage d'utiliser fireboard qui contient pas mal de bugs.
