Discussbot - Problème de mise en oeuvre
- DavidG
- Membre régulier
lorsque je veux modifier la configuration du forum (version 1.5.
Notice: Unknown configuration variable posted. in /home/htdocs/nantes/administrator/components/com_kunena/admin.kunena.php on line 884
Assertion failed!
Script: /home/htdocs/nantes/administrator/components/com_kunena/admin.kunena.php
Line: 885
Cette erreur est systématique dès que je veux sauvegarder la configuration...
Une idée sur ce qui peut provoquer ça ?
Note: j'ai également un problème d'installation de la version 1.5.9 mais je vous en parlerai plus tard
PS: je n'ai pas de hack installé comme indiqué ici
- DavidG
- Membre régulier
Avec en prime la page d'erreur complète:
Notice: Unknown configuration variable posted. in /home/htdocs/xxxxxx/administrator/components/com_kunena/admin.kunena.php on line 884
Assertion failed!
Script: /home/htdocs/xxxxxx/administrator/components/com_kunena/admin.kunena.php
Line: 885
Condition:
variable value
$0 "
key value
$function "debug_assert_callback"
[args] Nested Array
$1 "
key value
$file "/home/htdocs/xxxxxx/administrator/components/com_kunena/admin.kunena.php"
$line "885"
$function "assert"
[args] Nested Array
$2 "
key value
$line "182"
$function "saveConfig"
[args] Nested Array
$3 "
key value
$file "/home/htdocs/xxxxxx/libraries/joomla/application/component/helper.php"
$line "162"
[args] Nested Array
$function "require_once"
$4 "
key value
$file "/home/htdocs/xxxxxx/administrator/includes/application.php"
$line "136"
$function "renderComponent"
$class "JComponentHelper"
$type "->"
[args] Nested Array
$5 "
key value
$file "/home/htdocs/xxxxxx/administrator/index.php"
$line "67"
$function "dispatch"
$class "JAdministrator"
$type "->"
[args] Nested Array
$6 "
key value
$file "/home/htdocs/xxxxxx/administrator/index2.php"
$line "14"
[args] Nested Array
$function "include"
Warning: assert() [function.assert]: Assertion failed in /home/htdocs/xxxxxx/administrator/components/com_kunena/admin.kunena.php on line 885
Note: Le nom du site a été remplacé par "xxxxxx"...
essaie de re-transférer le fichier admin.kunena.php peut-être que ça ira mieux.
- DavidG
- Membre régulier
je viens de faire la demande auprès de mon administrateur.
Je vous tiendrai au courant du résultat de l'opération
Merci.
- DavidG
- Membre régulier
Le problème demeure. :S
- chr!x
- Dungeon's Keeper
Es-tu certain que la version du discussbot que tu utilises est compatible avec la version de Kunena que tu utilises ? Je serai à ta place, je passerai sur la dernière version de Kunena & dernière version du discussbot, car il se peut que le problème que tu rencontres ait été traité lors de précédentes releases.
Sinon, auparavant, avais-tu déjà réussi à faire fonctionner le discussbot ?
Edit:
à la re-re-re-relecture de ton message, un doute m'assaille : tu dis que t'as activé le discussbot... mais l'as-tu au moins préalablement installé ? :S Question idiote, mais sait-on jamais :side:
